park brake
texas-5-ton
10
Grandview, TX
I haven't even crawled under this thing yet to find out the problem, but our parking brake on our 5 ton does not work. The knob on the end of the handle is very tight (stuck) but it will not hold the truck. Anybody have any pointers on this?? Will this brake hold this truck on much of a grade with 1200 gallons of water? What do i need to do to fix this thing?
Hookin1
Chandler, Indiana
If the knob is stuck are your sure it is screwed all the way down? also under the truck at the rear of the tranfer is the parking brake it also has an adjustment nut on the cable down there.....make sure you chalk the wheels and release the parking brake b-4 adjusting it under the truck
texas-5-ton
10
Grandview, TX
well, i am guessing that is screwed all the way down, however this truck came from the east coast so could it be possible that the cable is rusted up??
westfolk
156
PA
After that....if the cable has a grease fitting(some do, some don't) grease the hel_ out of it. If it doesn't spray some on the cable ends and keep working it. Also wouldn't hurt to spray some WD-40 on the joints of the brake lever in the cab. Plus grease the parking braking system on the back of the transfer case. If I remember right there are five grease fittings.
westfolk
156
PA
Myself...I would not rely on the parking brake only in that situation. Depends on the grade. Empty maybe.
Just the same after you get it working play with it and see what it'll do. Better to test it and know what to expect. If you think the cable is froze spray some WD-40 or whatever in the top of the cable housing in the cab and give a pull or two and keep spraying. It should (over time) work its way to the bottom. If it's not really froze up it start moving again. Then grease that sucker.
westfolk
156
PA
Not really. The only REAL problem would be the cable. What's in the cab can be loosened up by working it and spraying it. Same with the back of the transfer case. Not to bad to do. The worst you'd have to do is change the cable if it doesn't free up. That's not too bad either. Just takes a little time.
