spicergear
Something else you guys might want to consider is that the drop side beds to the outside of the bedrail is 1" PER SIDE more narrow than a std non-drop side bed. The like six hinges are about 1" wide though. Visually...the drop side looks better fitting, TECHNICALLY...both beds are the same width if you count the drop side hinges. I noticed this when I swapped beds and could see just a little of the rear duals and hadn't seen that before.
