Price check on rod bearings, please
3,075
I called Clevite. they need a number off of the brg. They said they might be able to match it by NSN, but i can't download things at work. Anyone got the NSN for the rods and mains? Havn't tried Federal Mogul yet.
surpdlr
PA
cranetruck said:
Cost, best place to buy etc (LDT465-1).
Thanks
I have standard Mains in stock if anybody needs them. (Memphis buys them for me!!)
No rod bearings at present.....
houdel
10
Chase, MI
Re: RE: Price check on rod bearings, please
Only trouble here is you've got to inspect and the mike crank journals first. If the crank shows any wear (grooves etc.) then you have to get the journals ground and fit undersized bearings (yea, it sounds backwards, the bearings are actually oversized because the journal is actually undersized after it is ground, but industry practice is to call the bearings undersized). Even if the journal is smooth you still might need undersized bearings, so don't order them until the engine is torn down and you KNOW if you need standard or undersized bearings!
3,075
RE: Re: RE: Price check on rod bearings, please
If his engine was rebuilt at the depot level, the data plate should show that the crank was ground and to what undersize.
Boatcarpenter
Marlborough, NH
Speaking of rod noise etc; I can find oil clearance #s for the main bearing journals and bearings, but not for the rod bearing journals and bearings. Any help!
Thanks,
BC
JasonS
199
Eastern SD
My sealed power catalog lists two military standard engines: 427 and 478. I am assuming that these are the multifuels.
Rod bearing is 3355CP available in std, 10, 20, and 30. Standard shaft size is 2.9970/ 2.9980", housing bore is 3.2510/ 3.2520, oil clearance is 0.0022/ 0.0052", max wall thickness is 0.1254", width is 1.453". $24.99ea From Parts America
Main bearing is 4910M available in std and 10. Standard shaft size is 3.6210/ 3.6220", housing bore is 3.9370/ 3.9380", oil clearance is 0.0032/ 0.0063", max wall thickness is 0.1559", width of #4 is 2.127", balance is 1.230". $370.99/set from Parts America
SasquatchSanta
27
Northern Minnesota
Can the mains be changed without dropping the crank?
How about the main seals?
I've got to drop the pan on my truck to install some sensors and other plumbing and even though I've got good oil pressure and no knocking I'm considering doing a PM bearing and oil pump change out while the pan is off.
I was hoping I could take a chance on ordering and therefore having a set of standard bearings on hand when the pan came off in hopes the existing bearings would verify to be standard size. I assume the bearing size is stamped on the back side of the bearing. Perhaps I need to verify the bearing size before ordering bearings --- just didn't want the truck to be down overnight.
I can't imagine being able to mic. a main bearing journal with the shaft in the block so I assume if there is a way to change mains with the crank in situ one would have to rely on visual inspection of each journal AND "hopefully" the bearing size being stamped on the under/back side of the bearing insert.
I don't mean to hijack the thread but any insight would be appreciated.
devilman96
17
Boca Raton, FL
Seals can be changed with out doing anything to the pan at all...
Mains can be changed one by one so no you dont have to drop the crank...
Same with the rod bearings...
I would never trust depot tags or assume a bearing size... you really HAVE TO PULL the bearings and see what you have in the engine, assuming will land you in a parts mess!!
3,075
Yes there is a mic that you can measure the main journals with the crank installed in the engine.
SasquatchSanta
27
Northern Minnesota
Devilman Sez:
I agree --- I would never install new bngs without first verifying. As tempting as it is, given the uncertainty of not knowing if something has been previously turned I'm going to wait till I can verify what I need before ordering.
WillWagner Sez:
That's good to know --- thanks
