Push button glowplug issue
Dmoser
Rapid City, SD
A while back I put a manual glow plug button in my m1009. At first I was able to get them to cycle with the key on and get an after glow. Iv taken off the instrument cluster panel once since then and now I can only cycle them with the key off. Im pretty sure that I did t short any wires together. Any thoughts on this?
Warthog
245
OKC, OK
It all depends on how you did the wiring.
The simples way is to just use a one wire/switch for the ground wire on the GP relay. It uses the power from the GP controler card (which is only hot with the key on)
Without more details, you may be on your own.
Dmoser
Rapid City, SD
I went from the power on the 12v battery to the switch to the power side of the relay. I can try wiring it your way over the weekend though and see if that helps
Warthog
245
OKC, OK
Here is a diagram of the simplest way to wire a manual switch.
In a stock system the GP relay coil uses a ground signal from the GP controler. The Hot side of the relay coil is fed 12v when ever the key is on. The ground circuit is closed only when the controler card senses everything is ready for the glowplugs.
What type of GP relay do you have on the firewall? Any pictures?
m16ty
228
Dickson,TN
I think you have to rig the push button to the ground side of the relay. At least that's how my brother has his set up.
