rattle can camo, a rundown of my experiance.
I tried 3 brands available locally.
Magjic: No good, splotchy and applies poorly.
Krylon: Fair, applies unevenly and the green is to bright.
Rustoluem: Good. Colors are close and the newer cans that claim better coverage apply even and steady.
Rustoleum is harder to find around here for whatever reason, so I wound up using more of the Krylon. The green is more of a "frog" green however, the Rustoleum is a closer match and more of a flat finish.
Karl kostman
917
Fargo ND
I have ended up using the spray can and paints from Alan Haage in Supply Line, the spray can spray very evenly and the colors I use mainly three color NATO woodland seem to be very good as to what I am trying to achieve and his prices seem very fair!
KK
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Rustoleum is a much better paint especially when using a primer. Rustoleum Rusty metal primer is great.
104
12
Otisville/MI
Thank you for the timely post and the replies, I will soon be spot painting mine after sanding surface rust on the hood. I had been looking at other threads for advice, one more can't hurt but there are quite a few others.
