Rear brake hose for bobbed deuce
Bcurtman
Rosebud, Mo
I would like to know what part number / source you all have been using for the rear brake hose for your bobbers? Any pics on how you did it will be appreciated also. Thanks!
KsM715
142
St George Ks
:ditto: just plugged the t-fitting. However, when I did mine I decided to shorten the line. If you follow the lins up under the cab you'll find another fitting there. I took the old line off and went to NAPA and found a matching line 6" longer. (I moved my forward axle 5" back) Put on the new line, re-used the t-fitting and just blocked off the rear port.
429
Berkeley Springs, WV
I used an identical T fitting on my rear axle as what is on the front axle. I believe I got that fitting from one of the three T's found on the rear axle setup (one T per axle and one T to the axles). The T you would use would be 5/16" in and 1/4" out on both sides. Anyways, since I used that T fitting, I ordered a FRONT frame to axle hose for the rear.
