- 827
- 224
- 43
Hey All,
I have an 1986 M1008, and I just replaced the dimmer (high beam) switch. While I was at it I wanted to replace the Turn Signal / Multi-fuction / Combination (or whatever other name it is listed under) Lever, as the plastic is cracked.
However, I have searched all of the major autopart stores (napa, autozone, oreilys, advance) plus summit and other online companies. But I can not find the correct lever.
I of course also searched here on SS to see if I could find a part number or other info, and I expect that it is on here and I proabably just missed it somewhere or didn't type the 'right' word into the search.
Not sure if most CUCVs are this way, but my truck does not have cruise control, AND it does not have delay wipers. Only off, low, and high.
The closest Lever I can find is almost correct, Except it has the markings for delay wipers - Dorman Part # 49277. This is true for all of the part stores, they either have this one, or they have one with cruise, or they do not have one at all.
I have searched Civy K30 from years 1983 through 1986 trying to find a correct part number.
Does anyone by chance know if there is even the correct Lever still being made?
Or was a K30 with 'No Cruise/No Delay Wiper' a military only specialty?
~Thanks
Edit: Hummmm.... accidentally posted before I was ready, no way to edit title? Or delete post and start over??
~Thanks
