- 1,964
- 435
- 68
- Culver City, CA
This modification should cover most M809-series trucks.
My state does not require these appliances on my truck, but always wanting to keep safety paramount, I thought a reversing light and alarm would be a good idea to install. Last October I rebuilt my transfer case declutch cylinder, replaced all rubber air hoses associated with its operation and replaced the twin poppet valve on the transmission. I figured I could use the air pressure available when the reverse sprag was actuated.
So, I installed 1/4 Pipe Size, Female X Female X Male Tee between the declutch cylinder and reverse supply hose and plugged it for later. That fitting in conjunction with a Brake Light Air Operated Switch would be the basis for this modification to work. I purchased an ECCO SA917 Smart Alarm from eBay and a Grote reverse light for the M35A3 from Erik’s for the working end of this job.
Here is a list of parts I used for my project minus any hardware needed:
Rubber Shell "Y" Connector MS27147-1
Rubber Shell Connectors (qty 10) MS27144-2
Brake Light Air Operated Switch, M35/M54/M809/M939 etc, 11602160
Prestolite Wire For Military Vehicles, 16 AWG, M13486/1-3
Backup Light For M35A3, 01-6201-93
Med-pressure Brass Threaded Pipe Fitting, 3/8 Female X 1/4 Male Pipe Size, Adapter
McMaster-Carr
Med-Pressure Brass Threaded Pipe Fitting 1/4 Pipe Size, Female X Female X Male Tee
McMaster-Carr
ECCO SA917 Back-Up Smart Alarm (eBay find)
ECCO | Products
McMaster-Carr
McMaster-Carr
ECCO | Products
