Running like a champ...then missing smoking and no power
LloydB
Waverly, Tennessee
Black/ Grey emissions,
(Then..) Just a thought..Some (Not all) of the deuces with the lds engines will run without the in tank working.
However, Some run extremely rough without it.
Some will not run.
Check the fuel supply.
(In Tank Pump Clogged, or missing bottom spacers).
Thanks, I am going to pull the tank off and go through the fuel system step by step as soon as possible.
DavidWymore
164
El Centro, CA
Clear line isn't fuel rated but I like to keep some around to install so I can see if I have bubbles in the fuel going into the IP.
Is it a consistent big fat chuff chuff chuff miss like a steam engine? If it is, it is likely the head gasket between cylinders 5 and 6.
LloydB
Waverly, Tennessee
It is a consistent miss, but it was hit and miss when it first started.
Thank you for your help.
