Slant Hatch - Top and Bottom release levers pulled : ( Best way to realign?
DHumvee
Both Hatch Release Levers are pulled and the hatch is released at the top and the bottom. It's popped up a couple of inches and appears to be a little crooked. What's the Easiest and Best fix?
I have imagined everything from the struts launching the hatch through the roof of my garage to losing a of couple fingers and only then wishing I had asked you guys first.
TOBASH
Do I really need to do it?
nopics
DHumvee
These are the top and bottom latch positions. Maybe it's not crooked, just shifted forward a bit?
BLK HMMWV
Ok
So I have to ask was the reason for pulling both latches?
And what were you expecting to happen when you did pull both latches?
Asking for a friend.
BH
DHumvee
Ok
BH
It was like that when I bought it but thanks for the response.
DHumvee
Ok
BH
So you actually have a slant back, are a well known member here and only took the time to write a sarcastic response instead of looking at my pictures and offering insight into what might fix a problem? I didn't expect that on this forum.
BLK HMMWV
I didn't see any pictures when I responded.
I don't have a slant back any more for the record.
I'm sorry to have pushed your sensitivity button .
I will take a time out .
HoveringHMMWV
On my M1151A1, with the hatch raised in the back (normal access), I am able to ever so slightly push it left or right to adjust. I used this method when swapping out the hatch weatherstripping. My hatch also has forward and aft tethers attached to assist in closing or even slow the opening (but I wouldn't wrap them around a wrist). I would opt to adjust outside of the garage just in case those hatch springs still have some energy stored up.
TOBASH
BLK is an awesome member. He has also made it clear that he removed his Slantback ages ago.
I have no doubt that either something is out of alignment OR something is bent. You need an assistant. You need heavy magnetic handles to lift the hatch up and out. You need to measure and realign.
These tops open traditionally or rumble seat fashion. Attach to the pins closer to the rear hatch and see if she will show you how to realign the pins to the frontward latching mechanism. The striker pins are all adjustable. Maybe a few slipped due to looseness. Mine were out of alignment, so I realigned the striker pins to make things perfect. These vehicles are hand made. If the hatch is not original to your rig, you might have some massaging to do to make it fit. Don’t assume that just because the hatch came with your purchase that the hatch is original.
There are differences between some hatches, with some being more square. Ensure you have the correct hatch. I am not sure about the different hatch iterations. I have an old M1025
Less close up pictures and more pics from 6’ away might help us help you.
Good luck
DHumvee
Good luck
Thank you for your response. To clarify, the hatch worked good raising and lowering when I received it EXCEPT the lower handle was very hard to lift and unlatch the hatch. I wondered if the handle had been bent upward from hard use or had been pried. In a moment of genius on my part, I decided to see how a handle functioned properly without inspecting the lower handle from the inside ( bottom looks shut) and pulled the top handle. It sprung from being under pressure and raised a little. After dropping the tailgate and looking in, you can see that the bottom catches are not in the latched position. I'm going to pull it out in the sun and get some better pics. Thanks again guys.
