Solar Battery Tender for M923
sd39u
Shawnee KS
I've decided to add a solar battery tender to my M923A1 and I just ordered one from that auction website.
I was wondering where most of you have decided to mount the solar panel and the control box?
Thanks!
chadande
Eau Claire, WI
I made a little bracket and put the solar panel on the davit so it was up high and in the sun at just about any angle. I put the controller in the battery box under the seat.
pmramsey
191
VA
The military mounts the controller box in the first section of the battery box under the passenger seat closest to the door. The de-sulfator controller is the sealed area just outside the controller box. This works even without the solar panel installed.
sd39u
Shawnee KS
Thank You! I'm thinking of mounting the solar panel on the arm of the spare tire crane. That way where ever its parked it'll get some good sunlight.
pmramsey
191
VA
Your solar panel is especially good and it requires less than an hour of daylight to top up your battery due to daily battery discharge from disuse. Six-seven hours of daylight a week is all you need to keep the batteries topped up. Therefore, mounting the solar panel in a safe/secure place is by far the most important element when selecting a mounting location. You can store your truck in a cave and drive it only on Sundays and you will be fine.
