I found this truck online and have not been able to find any more information on it. I was wondering what all would have to be done other than the obvious single axle conversion, power steering, crew cab conversion, and wheel changes to run this? Would it require a lift? How about the axles -- would you have to go up to 5 ton axles to handle these tires? Would you need to do an engine swap to get enough grunt to use the truck to pull a trailer with a small dozer/backhoe/tractor/hay/whatever?
Thanks guys, sorry for all the q's. I just wanted to know the feasiblity of the project before dumping a lot of $$$ into it.
