devilman96
- 16
- 0
- Boca Raton, FL
I was reading a post yesterday regarding spin on oil filters and decided I need to quit being lazy and convert everything to spin on...
What I need are spare filter assemblies to play with... Its easy enough to use my own to a point but I would like to have a spare set OFF of the vehicle which would save a lot of up, down, back, fourth, size, fit, bolt, unbolt, etc...
The oil filter bases just need a adapter made to accept a spin on... I think I can use the current base by turning it down and threading it. (see pic) If so I could proably make this part as an exchange thing. I send you a threaded set you send me your old ones.
The fuel bases are a little more complicated, ether I need to make several parts to plug up the top and give a thread, build an adapter base, or modify the originals by plugging and tigging up the tops base holes and also doing an exchange deal.... Im still undecided what would be better both in quality and quantity...
Having the bases off I can also hydraulically pressure test them to make sure the parts exceed the filter gaskets and bodies.
If anyone is parting out a truck or has a blown engine I would like to ether buy the parts from you or work out a trade in exchange.
The trade would be this... I build them, you run them under the basis of the idea being EXPERIMENTAL until I, you, or we rack up enough miles to feel the end results are safe, surefire and problem free. The last thing I want is to come up with something defective and cost someone an engine.
