Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Some pics from the rear axel weight modification.
To get speedy at road traffic we take the original 2 x 1.3 tons weights off and build
a pair of 850 lb/each.
The UNIMOG tractor easily climb on the truck to piggy back on longer distances.
The video shows the tug fully loaded with the heavy rear weights and an additional 1100 lb front weight.
Ready for a funny tractor pulling.
Upon request of thousands potentially voters some detailed pics, recorded today. Cyclon air duct Front mounting plate with PTO for additional device , like snowbrush Pintle hook front.... ....and rear a screen to prevent getting gloving diesel carbon into wheelhousing of the planes 2 fire extinguisher Trany/torque converter oil cooler Additional headlights, used if standart headlight blacked out using a front extra tool Heater with engine coolant heat on drivers side and an additional diesel fire heater under the backseats which also is integrated in the cooling system...... ... and below the external 24V receptacle you see the heater exhaust tube, routing across the batterie box for better cold cranking. ... the two roof vents, the convoy light and the movable spotlight and last but not least.....don´t forget to put some wine bottle plugs under you wipers.
I find the easiest way is to post on utube, then simply copy the U.R.L there. then do a post on the steelsoldiers site and paste that U.R.L.. Thus, https://youtu.be/uSd_Qgx7-Vo
Then. VOTE for this hard worked over 8 years Restoration. (Please..).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
