- 12,195
- 329
- 0
- gainesville, ga.
RE: on the subject of towing
any other numbers, or any number thats starts with nsn-
Is the Oshkosh truck able to drive down the highway? Those things are massive. I remember climbing around on one at the motor pool but never got I ride. Was the truck purchased at an auction?M1075 said:Bruce is right (as usual). Never tow a heavier vehicle with a lighter vehicle. Unless you are moving something around locally or offroad, call in the big boys.
I think Ddoyle wins the prize for most well-thought out post in this entire thread.DDoyle said:As most of you know, I have a reasonable amount of experience driving ex military 6x6s - though there are many on this list who have more - DavidB comes first to mind, with Kenny right behind. I have all the right equipment, all the little bits and bobs, all the tech manuals, and a reasonable amount of coaching from a full time heavy wrecker operator with many, many years of experience. I've towed deuces with deuces many miles - if towed 3/4 tons with deuces many miles, I've towed deuces with ten tons many miles.
As mentioned, I've towed a 5 ton with a deuce on a vacant air field. I'd not do it on the open road, even with the air lines connected. The reason is simple, the risk is too great in my opinion.
I've got a family who loves me, and wants me to see another day - the highways are filled with moms and daughters, brothers and sisters, fathers and sons, all who are counted on coming home.
Towing is cheap - 250-300 bucks - I ABSOLUTELY mean no disrespect when I say this, but if the truck is not fully operational now (and it clearly isn't) if you can't afford the tow bill, you can't afford the truck - the repair, insurance, etc. will exceed the tow bill many fold.
Tractive effort is not an issue, with or without weight in the back of the deuce. IF - and this is a huge if - the towed trucks are operational, and you connect them to the prime mover - stopping isn't an issue. Control is the issue - and it is being marginalized in the two situation proposed. CAN it be done? Yep - some on here have attested to this - and at least one had considerable over the road experience prior. Do you have that background?
With all due respect to everyone here - it is quite likely that the Army is more knowledgable about MVs than any of us, and has undoubtedly spent more money studying MVs than us, and certainly has more experience than any of us. Ever seen a Stateside convoy with a deuce towing a 5 ton? Deuces certainly less expensive to operate than wreckers. Consider that the army walked away from wreckers on the deuce chassis in the fifties, because they were not big enough.
All it takes is one time estimating wrong - best case, like Brandon, you walk and get your stuff out of the ditch, more likely, you are explaining to someone "I'm sorry mam, I really thought I knew what I was doing and my truck could handle this, I'm really sorry I killed your family." Is the chance of having to say the later worth the few bucks saved?
Respectfully,
David Doyle
Why are the rear duals singled out in this pic but dualled in the first one?M1075 said:You could always use a M911 to tow the deuce as well. Here is what a deuce with 11R20 duals looks like behind one.
I popped those outer tires off to be within legal 102" limit. I don't worry about that now and just run with the duals.spicergear said:Why are the rear duals singled out in this pic but dualled in the first one?M1075 said:You could always use a M911 to tow the deuce as well. Here is what a deuce with 11R20 duals looks like behind one.
