steelandcanvas
- 87
- 48
- Southwestern Idaho
Either you guys are weight lifters or the 400# tongue weight is a crock. I didn't even try to lift mine, the guy I bought it from said don't even try. Maybe in a pinch?
steelandcanvas said:Either you guys are weight lifters or the 400# tongue weight is a crock. I didn't even try to lift mine, the guy I bought it from said don't even try. Maybe in a pinch?
Does anyone know of where I might be able to find a couple spare wheels and tires? Also, do the M105A2's use the same bolt pattern as a commercial wheel? If so anyone know what size tire would fit?emmado22 said:Also, if you have a spare tire/rim for the M105, bring it.. That will guarantee you wont get a flat.
I'm new to the game and have been looking but have only found one place that sells any, and they sell them in 10 count lots! I'm only looking for an extra wheel/tire or two. Can you point me in the right direction on where to look? Any links, or suggested publications?M1075 said:The wheels are large 6 hole pattern and the tires are 9.00x20, same as the deuce. Tires and wheels are readily available in the surplus market.
I believe it is an inch and a half.coyotegray said:I would like to flip the lunette. What size is the nut..?
