Trouble Loading Pages (takes 30 to 60 seconds per page)
misterbill64
Buckhannon WV
Any body else having problems with page loading? I have a laptop, ipad, and a desk top and all 3 take forever to load . started over the weekend , have had the ipad on different servers so know thats not the problem.
swbradley1
Modertator
1,915
Dayton, OH
Mine load fine. I'm on a 15Meg connection at home and 90Meg connection at work.
Both running Win7Pro and Chrome.
SCSG-G4
PSVB 3003
5,393
3,464
Lexington, South Carolina
First, clear your cache, then run a 'ping' test to the site, and a 'tracert' to see if it's taking too many hops to get there. Then run one of the many speed tests to see how much throughput you are getting to your ISP, and post all that information here. The local geeks will then have a better mental picture of your problem and will be in a position to recommend possible solutions.
5,075
SCSG-G4 nailed the first steps to take.
Next question is, what is your internet connection? Also define "different servers". Unless your Ipad is a wireless (service provided by wireless) even if you had different access points, I doubt you'd have different service providers (IE: Cable internet as well as DSL internet).
73m819
327
gainesville, ga.
1 -- What is a ping test and how do you do it?
2 -- What is a tracert test and how do you do it?
5,075
Start, run, type cmd, in the DOS window type "ping steelsoldiers.com" note the time it takes to respond.
From that same window (or if you've closed it, do start, run, cmd), type "tracert steelsoldiers.com". Most likely it's best to post up the results of the trace route. results. For example, here's mine from home.
C:\>tracert steelsoldiers.com
Tracing route to steelsoldiers.com [12.222.202.34]
over a maximum of 30 hops:
1 8 ms 1 ms 1 ms DD-WRT [192.168.2.1]
2 16 ms 16 ms 15 ms 70.159.160.94
3 18 ms 18 ms 34 ms 70.159.178.129
4 18 ms 17 ms 18 ms 70.159.176.38
5 18 ms 19 ms 21 ms 12.81.16.0
6 18 ms 17 ms 22 ms 12.81.16.7
7 19 ms 18 ms 23 ms 74.175.192.62
8 32 ms 35 ms 31 ms cr2.attga.ip.att.net [12.122.140.186]
9 30 ms 31 ms 31 ms cr1.nwrla.ip.att.net [12.122.18.2]
10 30 ms 36 ms 30 ms 12.123.153.37
11 34 ms 34 ms 33 ms 12.249.78.182
12 33 ms 33 ms 33 ms cr1-vlan10.gpt1.jmfnetworks.net [12.222.203.209]
13 33 ms 63 ms 33 ms www.steelsoldiers.com [12.222.202.34]
Trace complete.
As you can see, it took 13 hops just to get to the steelsoldiers web server from my connection.
73m819
327
gainesville, ga.
WOW, I can see how that would slow things down, EVEN on a fast connection, just one slow hop or problem would do things in
5,075
Yup, but it's always easier to blame the admin I guess. :patracy:
(That's just a joke, but honestly there's a lot of varibles I have no control over outside the server)
