Turn signal help
CUMMINS
Tull, Arkansas
I noticed the other day that my rear right turn signal stopped working, the bulbs are fine ,I'm not getting power to it, I tested the wires upto the flasher box, and I noticed that when the left turn signals are on 2 wires carry the flashing current one for the front and one for the back turn signals, but when I turn the turn signal to the left only one wire has a blinking current instaed of two and only my front signal works, from there the wires go from the flasher up to the turn signal actuator on the steering column and I can't find any shorts, Could any body help me with this,
jrosbo
Vandalia Illinois
Blinkers
On my truck the brake lights go through the turn signal switch. Each light has its own wire coming from the switch. 2 for the back, 2 for the front. So you might want to check the switch. Also I see several different switchs for sale, I don't know what the difference is. Maybe someone on here knows. (I'm sure more than me, I am new to this whole MV thing.)
