Turn signal
Hasdrubal
Vancouver BC
On my 86 M1009, all of a sudden my left turn signal doesn't flash. Replaced bulbs, still nothing. Looks like there is only one flasher for both sides and my right works fine. When I put my park lights on, the rear left is lit up but not my side marker and my turn signal-running light has a faint glow to it. The right side works normal. What gives here??? Any ideas??
JohnFire
Pottsville, PA
could be the switch but I would spend the $10 and get a heavy duty flasher, even though the other one is working it might be it. I have had problems similar but cleared once I replaced the flasher unit.
Hasdrubal
Vancouver BC
Well, picked up a new heavy duty flasher unit, that fixed the turn signals. Looked at the front running light/turn signal, the metal tab inside the bulb socket has broken off where it's supposed to contact the metal bulb casing. Will have to pick up a new one tomorrow, in the interim I'll temporarily fix it with a small piece of wire.
JohnFire
Pottsville, PA
The original flashers for these trucks are really garbage. I had problems before I hooked a trailer up. My signals were really fast, and with a trailer they didn't even work. Happy to hear that fixed yours.
AJMBLAZER
Paducah, KY
Okay...call me slow but are the front yellow lights on the side supposed to blink? One of mine does and the other doesn't. Just noticed this a while ago before the present problem.
