Uh Oh...M934
swbradley1
Modertator
1,573
Dayton, OH
Hope like heck they aren't as bad as the ones they once sold at WPAFB. Desert tan box trucks that had sat out interestingly enough in the desert without any upkeep.
But maybe you wanted encouraging news. In that case, fill it with fuel and drive it home.
archmark
20
Woodway, TX
Of Course...
..., now why didn't I come up with that solution. Greenjeepster, you're a genius, in spite of what everybody else says...
dmetalmiki
2,026
London England
Nice looking truck. Hope it drives as well as it looks. Someone pointed out it does not build up air. Take a tool box and compressor. keep us posted on your mission.
juanprado
2,737
Metairie/La (N'awlins)
If is not building air, there is a very common problem with the piston on the bottom of the air dryer sticking. Just shove a pen or pencil up the middle of the cup to reseat the piston. Then plan on R&R.
jeepsguy
Mechanicsville, VA
Hi. A friend of mine bought a van like this out of Chambersburg. The yard man drove it up to the gate. All it needed was a new soft top and air in the front tires. He drove it 170 miles back to VA. It had some bad plywood panels in the interior and the AC eqpt. was removed.
wreckerman893
Possum Connoisseur
15,612
1,984
If you can't get it to build air the two alternatives are flat towing it to a place where you can work on it or a RGN trailer. They are too tall for a step deck (ask M920).
I flat towed one for a fellow member with my M927A2 with the air lines hooked up between them for braking.
It was still a high pucker factor mission.
Good luck. It looks like a very nice truck.
Baradium
Salcha, Alaska
I'll also point out that some sites leave the air drain valves open on the passenger side of the truck, so before you get any tools out make sure they aren't just opened (if that was the case they might have them closed by the time you get to it anyway). My 923 was like that, I didn't notice the air was showing zero psi until AFTER I'd already put my bid in though... but when I contacted the site to make sure it was possible to drive it off they said they'd just left the valves open. That was at Yakima, WA.
