Valve Tappet Question
fhu667
Dallas
I pulled my pushrods out tonight, and on a couple of them it felt like the tappet stuck to it as I was pulling and it made a rattling sound. On one of them it didn't feel like the pushrod wanted to fall back into place. Is it possible / likely that the tappet came out of its hole and dislocated? I see from the TM there is an inspection cover, but it looks like a lot more work to get to it.
rustystud
2,389
Woodinville, Washington
It' very common to pull the lifters out when removing the pushrods. Get a flashlight and look own there and see if you can make out the lifter. If you see it then you can use a long magnet tool like mechanics do and fish it out. Then you will have to use the same tool to reinstall it and a long screwdriver (or something similar) to push off the tappet from the magnet. I've used this method many times before.
