VIN Number Confusion
satcong
Lynn Haven, Fl.
I have been looking at all this info that's given out, could someone please help me out? I bought a deuce W/W 25 Sep. 08 @ Pineville La.
37,334 miles, 562 hrs.,
date of Mfg. 1967 ?
MFG # 0225-19931
stock no. 2320-077-1617
SN: 4L-8848 or 8849 ??
contract no. DA-20-113-AMC-D7241 T
DTID: W42N6L81090007A( as listed on the invoice )
Is the DTID in fact the VIN Number?
:roll:
dk8019
55
Lovettsville, VA
So I have a similar question, I've only got these nubers on mine:
M109A2
Serial Number: 109394
NSN: 2320000771636
FSC: 2320
There's no year of manufacture or MFG on the data plate. What should I put on my SF97 request?
DDoyle
West Tennessee
Is the 109394 stamped into the frame? If so, the truck was built in Lansing, MI (rather than South Bend, IN). Do you have the registration number (which should be painted on the inside of the doors and/or under the hood)? From the number, my I am reasonably certain that this truck was built by Reo in 1952. Does the truck have any of the signs of being repowered from gas to Multifuel {hole in floor for starter button, instrument panel stamped of plain flat sheet metal (no embossed rib around outer edges), squared inner surfaces of the front fender, one bolted motor mount?
Hope this helps,
David Doyle
dk8019
55
Lovettsville, VA
David,
I'll check the frame, I'm guessing it does. I think it is a repower, there's a hole in the floor like you mentioned, the panel is flat as well, I'll need to check the motor mounts to confirm for a fact. Here's other pictures, about mid way down of mine:
http://www.steelsoldiers.com/index....pic&t=26278&postdays=0&postorder=asc&start=20
The van part was built in Lima, the engine is a White, so this may make alot of sense. I didn't know these were so old! The data plates in the truck seem that they were replaced at some point. So if it was built in '52 what model was it then?
DDoyle
West Tennessee
Based on those photos, I'd say your truck is definately a 1952 Reo that at some point has been repowered with a Multifuel engine and an overdrive transmission.
Best wishes,
David
dk8019
55
Lovettsville, VA
David,
Thanks for your help! I've got most of my information now for my SF97, what is my complete VIN based on those numbers? Is there something else I need?
MWMULES
351
DESOTO, KANSAS
Dave I need help in the decoding dept also . Just picked up my M109A3 with 2 others from our KC MVPA chapter at Ft Riley yesterday, 2 drove back one trailered. Mine has a redo plate without Mfg Name or date.
nsn 2320-00-077-1636
ID 0230-10304 4L467
contract DAA06-70-C-0001
Has a newer motor with an 87 mfg date and runs like a top. I belive from the contract # it is a 1970? It also has a MWO tag 9-2320-200-35-1 , feb 83, Please let me know so I can get it right for my form 97.
mine is the green on in the center. The desert one on trailer is missing the shaft between
transfer case and transmission antbody got a spare? Thanks in advance, Dave C
DDoyle
West Tennessee
ID 0230-10304 4L467
Dave,
The truck listed above (0230-10304) is a 1967 Kaiser-Jeep. I'd confirm that number by looking at the frame stamping. The registration number listed above 4L467 is not correct - the number is too short (one digit missing).
Hope this helps.
Sincerely,
David
MWMULES
351
DESOTO, KANSAS
ID 0230-10304 4L467
Dave,
Hope this helps.
Sincerely,
David
Dave I have since cleaned of the multilayers of paint of the left side frame rail just in front of the shock mount as the former #'s I sent were off the EtchASketch replacement dats plate. I found the following set of #'s
22 2793L
3 6 67
1072004
again thank you for the hepl, Dave C
