Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
There are two fuses and a relay that control the voltmeter.
First fuse is the 24v fuses that feeds the voltmeter and is controlled by the relay. Second is the 12v ignition fuse. When the key is on it feeds 12v for the relay to energize and send the 24v to the meter.
The voltmeter relay is under the center dash. It is next to the starter and GEN2 relays.
Also the 300 ohm resistor on the voltmeter has to be in working condition.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
