Waste fuels and filtering
Cgzmt
Thunder Bay ON
I am currently in the process of purchasing my first M35. I work for an airline up north that hauls all the freight and fuel into the northern reserves. I usually fly the super tanker, the fuel hauler, and always have residual left in the tanks. Every time we switch fuels we have to flush then dispose of the fuel. So right now there is a surplus of waste fuel barrels containing everything from unleaded, commercial, jet a, and turbine oils. So I have permission to misappropriate this fuel but now the dilemma, how to filter it? Most of it is clean, but I am sure sitting outside some water has gotten in, dirt and dust from the decanting procedure. I know I should wait for winter, all solids and water will sublimate to the bottom of the barrel, but I would like to get fuel year round. Should I be going the paper filter route, centrifugal filter, multiple high pressure filter, step down setup? How fine should I filter it down too? Most filters take it done to 15-30ppm, but should I take it all the way down to one? Thanks any and all for the help!
Beyond Biodiesel
37
Prescott, AZ
Very nice. I wish I had it.
Since all your fuel started out clean, and may only have collected the odd particle and some water, then the water is going to settle to the bottom of the barrels fairly rapidly, so just do not pump the bottom 10%. Just get yourself a decent transfer pump (20gpm); then filter the rest through a standard transfer pump filter and you should be good go. I would make sure the filter on the transfer pump has a water separator on it.
svd dragunov
grants new mexico
You lucky dog.
