What size socket to bar NHC-250 over?
US6x4
2,087
Wenatchee, WA
I can't fit a caliper in there to measure the nut on my M813 but I need to get a socket before all stores close down.
Do you M809-ers bar the engine over at the crank or at the accessory drive?
simp5782
Feo, Fuerte y Formal
9,264
Mason, TN
Thanks Wes. Are the crank and accessory nut usually the same size on an engine?
Crank is generally 1-1/8" least on my old one. i always use the accessory drive. One engine i have here uses a 1-3/8 accessory. another uses 1-1/8.
There is an engine bar over tool available. I got mine off amazon
US6x4
2,087
Wenatchee, WA
The nut on my accessory drive turned out to be 1 5/16". Luckily that is a socket I already own :)
2,425
Can be any of the 3 above, just depends.....yeah, those are old people skivvies....1 1/8, 1 1/16 or 1 5/16
US6x4
2,087
Wenatchee, WA
I see. So the outer pin inserts into the pulley bolt or something and the inner pin grabs a pulley spoke?
Zoidsfan77
Columbus, Ohio
No, each pin fits loosely into the 3 large holes in the pulley. No need to mess with any fasteners.
Sorry for the crappy doodle.
If it was light out I would take a picture of mine. I'm currently in the process of changing #5 and #6 injectors.
