Ls3rx7
- 47
- 18
- Tulsa, Oklahoma
Is there a tire bigger than 37” for the factory 16.5” 24 bolt wheels?
Welcome to the SS forums.Is there a tire bigger than 37” for the factory 16.5” 24 bolt wheels?
Interco makes several versions of 39.5" tires for 16.5" rims.Is there a tire bigger than 37” for the factory 16.5” 24 bolt wheels?
Do you have a lift? Do they rub?I got the Black Rhino Arsenal 20 X 12 with the -44 offset, Nitto's Ridge Grappler 38 X 13.5, they have the beads for balancing, nice and smooth ride.
With the -44 offset, they just stand out a bit more than the original wheels & tires
No liftDid you have to do a body lift with these?
Yes 2in body and 2in suspensionDo you have a lift? Do they rub?
I was looking at these wheels, how bad is the offset, does it look bad?Method 105 beadlock wheels, 17x8.5 & Yokohama Geolander MT G003 37x12.5R17
Went with civilian wheels/tires because of the price of stock tire sizes. Even used tires have a big shipping cost - not everyone lives near suppliers. The offset isn't perfect but I won't be carrying much load most times when it matters and my experience with military vehicles are that they're over engineered.
Lift? Do they rub?Finally got my wheels and tires! They are method nv605 20x12 -52 running 38x15.5x20 tire. View attachment 768492View attachment 768488View attachment 768489View attachment 768490View attachment 768491![]()
I know this is old. However, do you remember your offset?Mine has 17x8.5 GT Cepek wheels, with 40x13.5 Milestar Patagonia tires.
I'm looking at getting these same wheels with 40" Patagonia XTs for my M1165A1 (REV). Do you have any rubbing? Thanks!These wheels have the correct offset: http://www.hummerproducts.com/hummer-wheels.asp#17spokewheel&panel1-14
Here are some pictures of them on my truck in case helpful.
No rubbing at all with 40" Milestar Patagonia M/Ts.I'm looking at getting these same wheels with 40" Patagonia XTs for my M1165A1 (REV). Do you have any rubbing? Thanks!
Ended up going with Method 704HD wheels that have a +18 offset and Patagonia MTs (went with MTsNo rubbing at all with 40" Milestar Patagonia M/Ts.
