Rustyshackelford
- 10
- 18
- Tucson AZ
I found this in my radiator. It looks oily. Any ideas?
I don't know. Is that your understanding?Is it my understanding that the oil cooler lines can leak into the coolant?
You post this type of grammar correction a lot so I'm going to do you a favor and let you know that it doesn't make you look smart. It makes you look like a butthole.I don't know. Is that your understanding?
Yes you were asking for ideas. That is possible to. I also know a man that had his wife add oil to the radiator from an unmarked container that was an old antifreeze container with bar oil in it. Not her fault. She called him and he said just fill the overflow with antifreeze from the garage. See did. Wrong container. Ha.
You could have taken that in good fun. It reads like something in a Groucho Marx script.You post this type of grammar correction a lot so I'm going to do you a favor and let you know that it doesn't make you look smart. It makes you look like a butthole.
Thank you. I took out the jug last night and cleaned it out and I'll update once I've had a chance to drive it for a bit.Rustyshackleford: I had a bunch of gunk in the overflow tank of my M1009; none of it was oil though. I was unable to easily remove the tank to wash it out while the radiator was installed, so I shoved a high pressure garden hose in the tank and flushed the crud out for about 5 minutes. When the plastic tanks cracked on the radiator, I obviously had to replace it. I took the overflow tank out and gave it a proper cleaning and reinstalled it before installing a new 4 core brass Modine radiator. I'm not sure if my experience helps you at all, but I figured I'd let you know what I did.
