Wiring diagram for M880 Blackout lights
macawpat
Laporte, In.
Would anyone possably have a copy of the wiring diagram for a 76 Dodge M880 Blackout switch. I have new lights on order and a few wires under the dash from the switch that are just hanging there. They look like they should plug into the headlight switch but cant figure out where. Also have a few loose wires into engine compartment. Sometimes I can get the two front marker lights to come on but very dim. Rear will not light up at all. Any help would be greatly appreciated. Pat
Elwenil
40
Covington, VA
Look for TM9-2320-266-24P in the Tech Manuals section here on SS under Resources. In the back of the manual in the Special Purpose kits it has the diagrams and install instructions that should help you out.
macawpat
Laporte, In.
I checked out both sites and they just dont give enough detail as to the wiring at the headlight switch. I have one wire coming from my blackout switch that ends at the headlight switch but there is nowhere to plug it in. The front blackout headlight does not work and I am thinking that may be the wire that controls it because all other B/O lights work great.
