LDT-465 in a daily driver?
kawibrute
Clearmont/ Missouri
I have a few things here and there like the canvas top and a couple more gauges but other then that it is ready to go! FINALLY!! :beer:
I am going to change the rear end gears from 3.73 to 3.08 for lower RPM's at 60 and I am also going to put semi super singles on the rear once I find the right wheel adapters at a price I feel ok with:)
moriboy
22
SW OR
Here's another idea..How about putting a multi fuel in a modern pickup bed, and making it front wheel drive? I would think any Dana 60 front end would easily handle the torque. Or, even cooler would be to use a hydraulic pump to turn the drivetrain, like a modern hydrostatic tractor....
kawibrute
Clearmont/ Missouri
Fantastic! Tell us again what you used for a driveline and chassis rails.
The frame I built myself I run and own a Fabrication shop out of 2x4 3/16 square tube. I am using the spicer trans and the rear end is a chevy 12 bolt out of a truck. The driveshaft is custom made. The front end is a suicide solid axle from Speedway with a custom front spring to handle the weight and coil overs in the rear.
Ferroequinologist
Resident railroad expert
4,813
750
Liberty Hill, SC
Someone was mentioning putting one in a Dodge D500...
I just got that old D600 and I use it to collect WVO, and it sure could use a diesel... It only does 55 mph right now anyway, really needs a 5th gear or 2spd rear end. I do have a couple of spare LDTs... :twisted: I think it would fit in the engine compartment just fine, and the truck is rated for 24,000lbs... it is concidered to be a 2.5 ton. What do you guys think? I know it would get at least as good mileage as the 318 that's in it now. Fuel costs would drop to near free too.
http://www.steelsoldiers.com/conversations/85273-ferro-picked-up-his-fuel-truck-today.html
drjosjam
Dryden/West Bloomfield/MI
LDT Rat rod
Hi folks, I am new to this forum and to Deuce. I am the new proud owner of this rat rod and thought to revive this thread. It needs some work for me to feel safe driving it even though it is very much drivable as is.
I am not a military person, but a part time civilian physician at Detroit MEPS, doing physicals for aspirants to military.
I am wondering if there is anyone nearby me in SE Michigan who can help me with fab work and check the engine and trans out for me.
Thanks for reading.:)$_57.jpg
I am going to start a new thread as this is old, please follow it here.
http://www.steelsoldiers.com/showthread.php?129462-LDT465-powered-rat-rod&p=1603382#post1603382
