Anybody used Ace Rust Stop paint on their MV
lavarok
33
Fellsmere, FL
Beerslayer
55
Tualatin, Oregon
I haven't used Evapo-Rust, but I have used Rodda's rust converting primer and it is just amazing. All you have to do is remove the scale and loose paint. I do that by pressure washing at 4000 PSI. Then spread the stuff on and it converts the rust to a black phospate finish. It takes days out of refinishing time. I was always a sandblast to white metal kind of guy not am thankfully done with that now.
Andercomm
Parker County, TX
I see Home Depot sells this stuff locally, in 1/2 G, 1 G, and 5 G bottle sizes..
emr
24
landing , new jersey
POR you will find will peel eventually in areas that oil has penetrated the metal,I stopped using it years ago because of this, Rustolium rusty metal primer and top coat are an oil base, so it is just fine with a little imperfections when oil and grease stains may be prevalent.
Dukeboy
Palmyra Pa.
I've used multiple paint over rust paints in the past and have settled on Rust Bullet as my favorite. They have a UV stable version. The black shell is very durable, It does dry to a glossy mirror like coating however. There are other places online, but I've been ordering it through summit racing lately.
