$1.00 Dollar a gallon, Recycled ATF from the local 10 minute oil change
How many Deuce,Multi-Fuel owners will actually take the time to reclaim cheap fuel..?
islandguydon
787
Michigan
Ok guy what would it take to run my CUCV on this stuff? Cut it with Diesel? Sounds allot cheaper than Bio Diesel.
Your CUCV is like mine a 6.2 non turbo stock dog. I think its prudent to burn straight diesel with a quart of 20-50 motor oil for lubricating the IP. There is really no way to turn our engines into a multi fuel.2cents
whatadeuce
Loxahatchee, Florida
I have been thinking of tis, and I already own a transfer pump HOME made with an oil pump from a household oil burner. I believe its a webster pump and was used to pump #2 home heating :Doil. I may put a conventional 275 gallon storage tank from a home and leave it on my deuce. Once I relocate in Florida, in November, I know just where Im going to look for the tranny fluid too WHATADEUCE2cents
Crewdawg141
Southern Maryland
I have been reading adding 2 stroke oil to the fuel of a CUCV, you say 20-50. Which one is better or is 20-50 cheaper than the 2 stroke for you? I am hunting for ways of operating the CUCV in a cheaper fashion, so any input is greatly appreciated.
islandguydon
787
Michigan
The only reason I use 20w50w is, I got a few cases free from a friend of mine. 2 stroke oil is better in my opinion, I just am using up what I had for free. The diesel fuel properties nowadays is not the same fuel we had back when the CUCV was made. IMHO any oil is good oil in the fuel.
Crewdawg141
Southern Maryland
Thanks for the info, so 1 quart per tank is sufficient? Forgive me if this is a stupid question but this is my first Diesel and I want to make certain that I do not Eff her up in any way by lack of knowledge or experience.
Also, is Diesel Help worth anything?
islandguydon
787
Michigan
Mineral Oil...
A few months ago I contacted the local utility maintenance division. I made a good contact with the reclaim\demolition department. They told me there were several old transformer sites slated for demolition.
Today I got the call......!!!!!
I was given a list of 5 sites to go look at and confirm I can remove all the mineral oil from every transformer.
The utility company has a crew that will come in and scrap out everything above the concrete pads. They can not take burnt out transformers to the scrap yard while they are still full of mineral oil.
Pictured is the 1st site i looked at. There are 3 transformers all disconnected from the poles are you can see. This particular site was hit by lightning and has been dormant for 4 years.
The site print shows each transformer holds 420 gallons of straight mineral oil. ALL PC-B'S are clear. I am sure since there was a fire there is some water mixed in but thats easy to remove. At each base there is a drain ball valve pictured. My plan is to pump from the ball valve straight into the transfer tank in the A3. Then filter X 3 and transfer to a storage tank. From what I know, mineral oil is better for a multi fuel than straight diesel fuel. No smell either.
I will post an update when I get all 5 sites drained and a total gallons of fuel procured. BTW, All this cost me was my time to ask a few questions and maybe 1 days labor per transformer site to remove all mineral oil, sounded like a good deal to me.
davesgmc
134
Mclouth, KS
I know for a fact that in the state of Kansas ANYTHING but green diesel fuel in your tank gets you a court date and a HEFTY fine. Because anything except green diesel fuel means you didn't pay the tax on it.
BUT you can get a fuel blenders permit and make your own diesel. you can keep records and send in the paper work and pay the tax per gallon of fuel you have made.
The draw back from all of this is you have to put up a $5000 bond to the state while doing this, I certainly don't have an extra $5000 laying around to give tot he state so I can save a few dollars a year on cheap fuel.
I had my tanks dipped and fuel checked not too long ago actually. He seemed like he was really expecting to find something other than green diesel. He even admitted to making sure he checks all former military vehicles he comes across just for the fact that he knows that people run other than green diesel in them.
And truth be known ANY diesel will run on WMO or similar types of oil if treated right, etc. I have run the Detroit 2 stroke on old gear lube ,,,just glad I didn't have any in either tank when he checked this time.
islandguydon
787
Michigan
WOW sounds like KANSASS is strict. I did some checking around and there is no issue around here. Whats the big deal anyway...? Sounds like you got pulled over and harassed. I was going to try a diesel/mineral oil blend in a MEP003 to see how well it runs. In Kansas is there an issue with power generators or just DOT regs..?
islandguydon
787
Michigan
Not to pick on Kansas but, I have read a few threads on how they don't like MV,s and some are illegal to park in town. Thanks for the intel Dave..!
Blind Driver
11
New Albany, In
I'm calling my two local utility companies tomorrow :beer:
Ask me if I give a gnat arse :doghead:
islandguydon
787
Michigan
If it makes anyone feel any better Mineral oil is clear without any red dye. So if you mix it with diesel you are still green on any dip stick. Today we are collecting at the first site then Sunday the next. I have a job during the week so the only way for me to collect in the daylight is on the weekends. Pictures to follow.:driver:
davesgmc
134
Mclouth, KS
thats only if you are all upity and live in an all upity county, and you are in charge of a local military vehicle organization and think that you are all that.
thats all i have to say about that.....lol
