Jimc
- 1
- 18
- Mullica, nj
Thats all thats in the flywheel. There are a few small dash marks around the pc mark but other than that, thats all you need. Each timing button will adjust timing 1/2 of one of those marks.
Jerry, David is buying an IP from me. He said that the numbers on his old pump are 1.09 and his button is a "1" which is .119. The IP I have for him is 1.080, SO I take the 1.09 and add the .119 which is 1.209. I then take 1.209 and subtract 1.080 to get .129. I now need to see if I have a 14 or P size button for his IP since .128 is the closest to .129.Congrats David!
Someone please disabuse me of this notion......My impression over time is that any IP (with it's proper button, stamped on it) is a "drop in" to replace any other IP. The only time port closing dimensions really come into play is when you are trying to install an IP which has not been matched to a button and trial and error via flow method with a known test button is required and button size is adjusted from there. Shims follow blocks...buttons follow IPs? I know we have had this discussion before but my mind is growing feeble and David's experience just reignited a lingering spark.
Jerry
