gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 747
- Cincy Ohio
That does make sense, my bad.
Seems we had a misunderstanding of terms in the first post.
I always presoak my parts in "Evapo-Rust" or "Metal Rescue" . This way the rust is almost gone before I try and remove any bolts or nuts.Those were that fuel lever.
You pull the "Jesus clip" out of the peg.
Cut the safety wire.
Un-screw the two flat head screws and remove the "bridge".
Slowly and carefully pull out the fuel shut off rod.
Then you take the assembly to a bench vise to take it apart. The nut that holds it together can be rusted on pretty good. I have had about 30% of them snap the shaft. once your in this far, it can go wrong if your not real careful.
Do you have anywhere near you that does "EDM"? I have some from a different AMbac pump, but the round shaft that goes into the lever is a tad big. An EDM shop could fix it easily.Where can one acquire the pin that goes into the end of the shutoff/fuel shaft. Mine has broken off flush, from a stuck piston in the hydraulic head I'm assuming.
Warthog, can we add these pics to the sticky? (post #19)Sometimes they get crud in there and you might have to take it apart to clean it up. You might be able to see in the second pic the rust I had to clean up.
That piston is a precision fit item. If it leaks any you will loose power.No sir. I called around to all the shops around here, and there isn't anyone who does edm. Nobody will touch any part of the pump, or the hydraulic head either. They act like its radioactive or something, and try to get me out the door as quick as possible it seems. They all say to just get another pump, but, they don't have any leads or access to finding a replacement.
I'm pretty sure I can get the piston freed up in the head easily. I'm not concerned about that all that much. Just the little pin in the back that is broken is my problem. If it was to make a new one, how hard of metal does it need to be? Any places that sell parts or places to call about such said parts. I've looked around some, to no avail. Thank you in advance for help.
I have seen the exact specifications of that pin in the TM'sWhere can one acquire the pin that goes into the end of the shutoff/fuel shaft. Mine has broken off flush,
Look in TM 9-2910-226-34 page 3-110.......... Just the little pin in the back that is broken is my problem. If it was to make a new one, how hard of metal does it need to be? Any places that sell parts or places to call about such said parts. I've looked around some, to no avail. Thank you in advance for help.
