gimpyrobb
dumpsterlandingfromorbit!
- 27,787
- 773
- Cincy Ohio
Yep, not cheap by any means!
You will be time and effort ahead if you just get a 5ton, crew cab it, and put a deuce bed on there.Ok guys I have been thinking hard about what I want to do to this truck. After spending time with CSMDavis I realized 1 main problem that I hadn't thought of with a truck this size. It is not designed for someone of my size to be comfortable in it. I am 6'7" tall so I take up a lot of room in that small cab lol. This led me to decide on making the truck a crew cab. After searching around I have found some pretty nice crewed dueces. Most of them are bobbed though I don't want to do that. Also after researching on here I will more than likely go with 5 ton axles to swap to full air brakes. Being as I have to service everything anyway why not upgrade. It was also suggested to me by CSMDavis to relocate the axles farther back and a little farther apart to help with ride quality and allow for more tire options. The electrical wiring on the truck is also shot so I will be replacing all of it and going full LED lights. Lastly I really don't want to shorten the bed to do the crew cab so I was thinking of extending the frame to allow the full size bed to still fit onto it.
What do you guys think? Any tips or tricks would be greatly appreciated. I want this truck to look like it rolled off the line when I'm done. My goal is to have a one of a kind everyday driver built from a duece that I can drive comfortably.
