stuck in 1st gear
m16ty
225
Dickson,TN
Sounds like it's stuck in two gears, locking the trans up.
Transfer case wouldn't go into neutral?
dmetalmiki
2,034
London England
This is devleoping into a whole heap of trouble for you. So the Gearbox is Stuck between gears? And the transfer case is locked up as well? One or the other Might be siezed holding the other jammed?. It will be interesting to hear what was wrong and how you fixed it eventually.
billyzz
rapid city sd
well
a 50 year old vehicle with an unknown past
i wouldnt say im happy
but more like resigned
billyzz
rapid city sd
update
transfer case was full of ice
there is slight rust on some of the gears but as soon as the new carb comes i will install it and try to drive it home
billyzz
rapid city sd
snow/rain ran down through the window gaps
down the dash
and funneled into the hole the shift stick lever goes into
the mechanic showed me well over a gallon of water and the rest was p-nut butter milkshake
