Power steering woes
topo
277
farmington NM
This pump set up is on my M52a2 that had the multifuel removed and a civilian Mack endt 673 put in . The pump is the pump from the old multifuel whith the in side parts reversed to turn the right way . it is a simple set up that has worked very well . I posted this because it is very close to the pump in question .
WV New Guy
Berkeley Springs WV
Heard from C&C no luck waiting to hear back from part target but not being a government organization or provider to the government might be a stumbling block . Has anyone used them for a personal purchase before?
Im thinking Monday will be the soonest I hear from the other vendors.
WV New Guy
Berkeley Springs WV
Thanks to Swamp Donkey I now have the DANA , EATON, and Windward part numbers to cross reference . I know my local NAPA has gotten pumps for the NHC-250 motor for a couple of other guys but my 8.3 is the first on the mountain .
Thank you all for the assistance .
Swamp Donkey
The Engineer
123
Gray, GA
You don't have to be the government to order from most of those parts sourcing folks. Expect prices to be about what the government pays though.
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
Did csmdavis actually answer? I will be at his place in a few hours.
Sent from my SM-G860P using Tapatalk
WV New Guy
Berkeley Springs WV
Yes Wes he answered the phone and I got some great pointers , tore all the old lines out today not sure if I should also try to replace the cooler ,and the cylinder also . Waiting on some contacts to email back or else I will be driving up to philly and eastern to get one.
WV New Guy
Berkeley Springs WV
Ok got a new pump ,hoses ,filter just wondering exactly what fluid would be correct for the power steering pump . I have been told that 15W40 would be fine but I'm a little Leary of that ? Any pointers ?
topo
277
farmington NM
I have tried 15/40 and thought it was to heavy . Regular power steering fluid is working fine my reservoir is a lot smaller then what I had and the fluid gets warm as is should but not hot.
MtnSnow
15
NSL, UT
The Lubrication order for the M939 trucks call for 10w oil (OE/HDO) most just use standard 10w hydraulic oil
Wildchild467
59
Milford / Michigan
Make sure your drag link and slave cylinder ends are adjusted properly. If there is slop in them, it causes issues with the power steering.
silverstate55
Unemployable
2,126
1,082
UT
I replaced all of my p/s hoses & connections, completely flushed system and filled with p/s fluid. Works great.
Kept having leaks around pump & reservoir; took reservoir apart 3 times and installed new O-rings, finally I thoroughly cleaned mating surfaces of pump & reservoir for a thin coating of The Right Stuff. Hasn't leaked a drop since.
When installing your new reservoir & pump, you might consider a thin coating of sealant between them to avoid future leaks.
juanprado
3,131
Metairie/La (N'awlins)
A friend did the hose for me is it the wrong stuff? View attachment 640975View attachment 640976
While it might work it is technically wrong. Air brake hose is not rated for oil/hydraulics. Yes I know it has a teflon nylon core. Hose for oil will be specked with a different DOT rating.
Mine came with dexron in the power steering. Dexron or power stg fluid is comparable and is better since it has anti foam and anti wear additives in it that plain ole 10W or 15w40 motor oil does not.
Just ramblings from my previous life selling parts for 20 years......
WV New Guy
Berkeley Springs WV
Pick up my new DOT hydraulic hoses with new fittings next week done by a local shop here that has been doing it for 40 yrs . New stuff is way nicer than old stuff shop said the cooler hoses were actual vehicle heater hose . Now we got proper rated,application hoses . Pics next week of the hoses and pump install thanks for the help as always.
grendel
12
Derry, NH
Any idea what size the fittings were? My cooler is leaking, so I want to go aftermarket with AN hoses.
