What did you do to your trailer today.
tobyS
816
IN
Listed my S-788 in the parts classified for anyone wanting an enclosure that would make a good camper... trailer or HMMWV mounted.
Daughters wedding takes priority over my camper-trailer project.
tobyS
816
IN
Well it fit an M105 a2
If you are referring to my S-788 shelter, no, will not fit on a 105 without serious modification or going back to the bare frame (a viable option and you could sell a clean bed).
You bring the 105 up, I'll take the bed in trade and I'll mount the 788 to your frame!
Here is the 1101 that I modified to put it on. The 788 is about the largest shelter that was designed to fit the back of the HMMWV and it is larger than the S-250 (thus more room).
Here is a link to the ad. I'm open to reasonable offers, this is a very nice shelter.
www.steelsoldiers.com/showthread.php?169908-Gichner-S-788-(drone-control)-El-Eqt-Shelter
wheelspinner
1,511
North Carolina - FINALLY !
yes thanks tobyS I'm going to lay a piece of sheet rock with a 2x4 down the middle over the top the sheet rock will start to pitch and give it more of a runoff.
I would suggest 1/4 inch plywood. The drywall will absorb moisture and fail over time making life miserable for you when you have to clean it all up and redo it.
TNriverjet
22
Nashville, TN
Did some painting on this M-1101. Here are "before" photos
Here are some in process... hand painting credits to my daughter!
And here are some completed photos.
two.fiveM35
11
Victoria , Texas
Used my a2 to haul items to our new house and haul carpet to the dump. After about 300 miles, I think the shock in the brake actuator went out. Now when I stop, the trailer brakes violently IMG_1026.jpgIMG_1021.jpg
Tinstar
1,709
Edmond, Oklahoma
Used my a2 to haul items to our new house and haul carpet to the dump. After about 300 miles, I think the shock in the brake actuator went out. Now when I stop, the trailer brakes violently View attachment 692774View attachment 692773
Easy fix.
Croft trailers has the shock in stock.
That shock isn't cheap no matter where you buy it.
Would you post a pic of your hitch setup?
tobyS
816
IN
Until fixed, make a block of wood and put it in place, perhaps secure with tape, so it doesn't come on at all. Unless loaded heavy, your truck can stop it without brakes.
