- 3,390
- 1,443
- The actual midwest, NM.
Or you could make reusable gaskets with the appropriate silicone.I'll order my gaskets for the diffs today.
I have a factory spicer dana 60 gasket installed on a 100% clean / dry / no oil yet axle . thick factory cover and flat checked .Or you could make reusable gaskets with the appropriate silicone.
Fixed.That last picture was an accident. Can a moderator delete it ?
So do I, which is why I suggested making a reusable gasket from RTV.I'll stick with gaskets. I hate cleaning RTV off surfaces.
Have the parts for a 700r4 swap already. If the th400 gives up the ghost, I'll just have to get a torque converter. Going thru all other fluids today.OK you must change out the transmission fluid and filter. I know a lot of people think there is no harm if a little water gets into the transmission but they are wrong. In a few years from now you can be driving along when suddenly your transmission takes a total dump on you ! You ask yourself "what did I do to cause this ? " . You totally forgot the time you "submarined" your truck in the flood. Read this article from "Raybestos" the leader in transmission clutch plate manufacture.
View attachment 694155View attachment 694156View attachment 694157View attachment 694158
I've seen this happen so many times, especially here in the Pacific Northwest. Guys take their "rig" out for a little fun and then later the transmission goes out for no reason at all ! I ask did you ever take it out in the river or mudholes ? They always answer "of course but there was no water in the transmission when they checked" .
That is good planning ! Who knows. If you totally drain the transmission fluid you might still have a good long life out of it.Have the parts for a 700r4 swap already. If the th400 gives up the ghost, I'll just have to get a torque converter. Going thru all other fluids today.
Sent from my SM-G930T using Tapatalk
