Best way to remove rust from 24 bolts wheel?
T9000
370
California
I left the spare tire outside for a few weeks when it happened to rain…and now several bolts have what appears to be some surface rust:
What would be the best way to remove the rust without affecting the threads? Brass brush wheel? (with actual brass wire, not just brass covered steel?).
And what should I apply to prevent it from rusting again? (none of the active wheel bolts on the truck have developed any rust, so I presume it’s because this one was static, which I am thinking it would also be static when mounted on the tire carrier and it may rust again?).
Thank you!
MarkM
1,146
2,096
WOBURN. MA.
That stud cleaner looks like a great product. I touch-up any discoloring studs with a silver wheel touch up pen and have been doing that for years. I cut up some rubber that just fits over the lug nuts and painted the wheels with some spray can Rustoleum matt black. Wheels always look great.
Mark
20210501_185238.jpg[ATT
T9000
370
California
Mark
View attachment 861548[ATT
Your wheels and the whole truck it's like a show piece, a beauty!
I repainted the wheels with RAPCO flat black when I replaced the tires and will redo it as this tire vibrates at higher speeds and will have to re-build it again (that's why I made it the spare tire) and will checkout the Rustoleum matte black you mentioned, which looks a little glossier.
MarkM
1,146
2,096
WOBURN. MA.
Stainless is not as strong as hardened steel. Just clean them and paint them besides changing them out is a PITA.
Mark
blutow
501
Austin, TX
Does anyone know if these bolts come in stainless steel?
I don't think stainless would be a good material given the torque requirements and the lock nuts used. I had to replace a few studs with galling issues when recently assembling my 24 bolt rims, I can't imaging how bad the galling would have been with stainless studs.
The stock studs are lightly galvanized, I assume you are getting a little rust in places where the zinc has worn through and maybe something corrosize got on them (cleaning agent?). I'd replace any rusted ones if they bother you, it's really easy to knock them out and pull a new one through. They run about $2 each new and I'm sure you could get used ones for next to nothing (I've got 48 extra in my take-off 12 bolt wheels). You could knock off the rust with a wire wheel, but that's just going to take more zinc off and the rust will return. I'm not sure I'd use that stud cleaner shown above for the same reason. Some anti-seize paste would possibly protect them and prevent future rust, but it can be messy if it gets on the flat black and some say it's a bad idea on wheel studs.
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
There are about 8 different size brush dies you can get down to a 5/16 size...
They taken off everything. Anytime a wheel is changed they should be cleaned anyway.
You can just get some Teflon to brush on. Or the clear spray
T9000
370
California
I ended up using some Rustoleum Rust Disolver, it supposed to be safe on metal (not acid based) and ads some protection after removing the rust (the surface looks like it has a slightly darker than the original bolt color oxide layer, which could be some formed protective coat, but most likely it’s just marketing bs, we’ll see how they hold up).
I picked this one because it is a stickier jelly and it was in stock (the reviews are ok too).
I only put it on the bolts, didn't do the nuts to not get too close to the wheel paint, and left it on for about 40minutes, but I could tell it started to work much sooner as I was still applying it.
Next step is to re-build it with less runout, plus a few that are on the truck…which also means lots of cold ones in the process lol
EDIT: I spoke too soon, there is a fine print (half the other fonts size and dark gray on gray background) on their web site saying - note: Jelly formula does not contain the 12 month rust inhibiting properties
Thank you very much Rustoleum, now I will have to redo it with the spray gel formula, but applied with a brush so it doesn't get sprayed allover the tire.
T9000
370
California
I know some people like the shiny look on the studs, but I don't, so after I do mine they get a coat of flat black paint. No rusting issues.
Actually the other studs on the truck were painted black to match the wheels, I like the overall look, but now are chipped because I had to redo the tires a few times and didn't repaint it yet. I didn't care about the silver look either when they look beat up, dirty, rusty, etc, but that was until I saw Mark's, with that high definition look..it pushed my OCD button lol...like I don't already have enough things on my plate...not sure why, but that clean raw steel does something for me, like my milling machine steel table...I somehow connect with it...lol...yeah I know, another nut case :)
blutow
501
Austin, TX
+1 on this, I really dig the look of the all the silver studs/nuts against the matte black. I guess that's why so many wheel companies have copied the theme with excessive fake bolts on all their wheels.
I promised myself I was going to leave the truck rough around the edges and keep it in "gently used" condition just as it came from the military. I couldn't help myself on the wheels, my OCD took over because a couple of the rims I bought had some surface rust, so needed some attention. Once I got started, they got the full treatment, including individually cleaning the paint off all 120 nuts.
MarkM
1,146
2,096
WOBURN. MA.
Lol sorry to bring your OCD to a boil LOL
I really like the look of the silver studs and people alway comment how hard it must be to have to pull off all those "Lug nuts' to change a tire. The Matt/Satin Rustoleum paint really holds up compared flat paints. Try the silver paint wheel touch up paint as it's quick and holds up well.
Mark
jkcondrey
141
Rutherfordton, NC
Just for giggles, look inside your frame rails when you get a chance.
T9000
370
California
Mark
What silver wheel touch up paint are you using? Some have more metallic flakes than others.
T9000
370
California
Hahaha, it's good to hear that I am not the only one :)
tgejesse
289
Maryland
Is it best practice to paint the bolts after replacing? I just put all new hardware and now I’m worried it’ll rust
Coug
4,740
Olympia/WA
Painting everything will do a lot to protect it, and won't cause any harm unless you somehow manage to really screw up.
I know of no reason why you shouldn't paint them.
