cucvrus
- 10,501
- Jonestown Pennsylvania
The only way to know for sure is to take it all the way apart and look. The problem is, any little bit of water and schmoo gets past those old seals and it will seize up those small bearings. Mine were toast on one side, but the other was not as bad. Youll just have to take it apart to see
Thanks you were correct
[/QUO
Can anyone tell me does the spindle bearing go in a ,certain way up or down
In my limited experience it seems that nobody has ever even seen that bearing let alone replaced it! Almost every truck I've ever torn down (1st time) that bearing was either dry as a bone or seized up or both.View attachment 873617
The spindle bearings are inside the spindle.
