Mep-802a aux fuel pump trips breaker?
ribs1
Michigan
Hello Again,
Since I got this repaired I have not tested the aux fuel until today. The unit is shorting again when I connect to aux fuel and try to prime. The aux fuel prime does work when not connected to the fuel drum. When connected to the fuel drum it shorts. I replaced the dual float assembly last year. I might just give up on using aux fuel and just fill the tank but it would be nice to be able to connect and use my drum. Looking for opinions. thanks
ribs1
Michigan
You say it shorts out. Tell us WHAT it does when it Shorts out.
Have you tested the AUX fuel pump- Its simple. Un plug it. The plug has two pins. Apply 24 VDC to the two pins. It works or it arcs .
Hello, it throws the cb1 breaker. I have not tested the pump itself. This only happens when the fuel line is connected. When fuel line is connected to fuel drum it trips the breaker. When fuel line is not connected the aux pump will run when set to prime.
Guyfang
27,263
Burgkunstadt, Germany
Other than the Hello, this is just what I wanted to know. But I guess you know more about this than I. I wish you luck in the repair of this set.
ribs1
Michigan
I'm sure I don't know more about this than you. Sorry about the wording, I came in to check your message then had to go right away. Thanks
Guyfang
27,263
Perhaps I am just being a curmudgeon tonight. Old an in the way. Sorry too.
Is the gen set grounded?
Is the hose you connect to the Aux input fitting, and run to the Aux fuel source, a military hose? The reason I ask is that the military hose has braided steel wire in it. The brass fittings on the ends of the hose screw into the hose, and make contact. So the hose can in theory, conduct voltage. Is the end that goes to the fuel source, the input fitting, insolated from the fuel tank? Or is anything else hooked to the tank?
Take the end off the fuel source, Put the S1, (start switch) in the AUX prime position. Take the free end of the hose and touch something that is grounded. CB1 pop? If not, then touch the hose to the fuel inlet fitting on the fuel source. CB1 pop?
justinn
33
THE GREAT STATE OF TEXAS
Does it trip the breaker the nano second that you trigger it, or does it get a couple or few pumps in, then trip?
Even if the pump runs with no load on it, it could be on its way out. Increasing the load(amps) on the pump by drawing fuel out of a drum could be a potential culprit as well.
Justin
ribs1
Michigan
Hello. Thanks so much for your help. The hose is the correct military hose. The genset is grounded. It's connected to the house. The ground wire goes into my transfer switch and then to house ground. I'm not sure about the second question. The input connects into the standard dip tube usually used with this set and into a 30 gallon steel drum sitting on the ground. Nothing else is hooked to the drum
I will try your procedure in the morning to test this.
Thanks again so much for your help.
ribs1
Michigan
Hello. I am having this problem again. I solved it before by just not using the aux tank. I think it is still the dual float as I can push in the breaker and it will run on the house tank no problem. Sometimes when I turn the dial back past the aux fuel indicator it throws the breaker. Can I just disconnect the duel float and use the house tank only? Any reason not to do this?
Here's a little more history. The generator ran fine for years until I bought a 55 gallon drum auxiliary tank and tried to pump fuel from it. I replaced the dual float with a brand new one from a member here. It seems to me the most likely culprit now is the auxiliary fuel pump. Any thoughts?
Guyfang
27,263
Hello. I am having this problem again. I solved (Ignoring a problem is not solving it) it before by just not using the aux tank. I think it is still the dual float as I can push in the breaker and it will run on the house tank no problem. Sometimes, (what means sometimes? How often? Was the set fuel tank full, empty, half full?) when I turn the dial back past the aux fuel indicator it throws the breaker. (If the tank is low enough, then the FL1-FL2 float system tells the AUX fuel pump to run, so if this in fact is happening, its not the floats fault. Take the AUX fuel pump out, and test it. Hook it up to 24 volts and see if it pumps, and pumps enough.) Can I just disconnect the duel float and use the house tank only? (If you do this, why unhook the FL1-FL2? If you do that, then the set will simply empty the set tank and run out of fuel. And then you will have to purge the fuel system to get air out every few hours. Perhaps you need to get in the -10 TM and read about how the fuel system works. ) Any reason not to do this? (Yes)
Here's a little more history. The generator ran fine for years until I bought a 55 gallon drum auxiliary tank and tried to pump fuel from it. I replaced the dual float with a brand new one from a member here. It seems to me the most likely culprit now is the auxiliary fuel pump. (Try this. Disconnect the AUX fuel pump. Then start the set. Move S1 back and forth between normal run and AUX pump. Does CB1 pop? Or not?) Any thoughts?
ribs1
Michigan
Sorry about that. It wasn't solved, I just didn't get to it. I will disconnect the AUX fuel pump and try. I have decided not to use AUX fuel as I don't use the generator enough to store a lot of fuel. I also don't really have much else that uses diesel fuel either.
Thanks for your help so far.
I just tested, turning S1 past AUX fuel trips the breaker all the time unless I turn it quickly.
