Ground Rod Kits
jonesal
Mission Specialist
72
Brookings, SD
Who currently carries the kits? Either the basics ones in three sections or the fancy ones in canvas... I've inquired around and everyone seems to be out.
Thanks,
Allen
jonesal
Mission Specialist
72
Brookings, SD
Either of these two would suit the bill (reproduced from other posts on SS). The basic kit is what I need for mobility and the fancy canvas kit would just be cool have.
Also, does anyone have the most current NSNs for either kit? I've seached at vendor sites and am coming up blank.
Let's push it here... does anyone have the correct hammer/extractor as well? NSN number?
Thanks,
Allen
Lieutenant
3,347
58
Michigan
One should be so lucky to have a set in new condition. The ground rod set that came with my generator had to be re-threaded, after the rods were straightened that is.
I do have the hammer, it's not for sale, but I can provide pictures and dimensions if needed.
Update: I do have NOS Slide Hammer sets ( NO GROUND RODS). See the classified section.
OLDCHEV4X4
Glenmoore PA
I have the slide hammer and misc stuff, but no ground rods or couplers. I was told i could get the ground rod and couplers at a electrical supply, but no luck yet.
319
Lieutenant
3,347
58
Michigan
Grainger carries a rod set. Part # 2KXN1
I'll post photos and dimensions of the hammer on Tuesday.
319
Lieutenant
3,347
58
Michigan
The hammer dimensions are:
Height 5"
Diameter 4"
Center hole 5/8"
Handle length 6"
Handle dia 3/4"
Weight 20lbs
Flat disc on driving rod:
Diameter 2-1/2"
Thickness 3/4"
Center hole diameter 5/8"
Thread size on rods is 5/8-11
OLDCHEV4X4
Glenmoore PA
According to the Grainger web site there are two 5/8" x 4' rods, a connector, a ground clamp, and a drive sleeve.
They dont screw together. When you pull them up, they might come apart.
So it looks like you would have to thread them, and make a threaded coupler.
Nonotagain
Parkville, MD
While if I were purchasing these rods I would thread them together its just as easy to drill the coupling collar and rods and install a screw in each joint so that they stay together when you use the slide hammer to remove them from the ground.
That's the KISS engineer in me.
319
Lieutenant
3,347
58
Michigan
Another fly in the soup is that the standard accessery box on the generator trailer is only 3' 4" long. So no 4' ground rods.:|
This ERITECH does make 3' threaded sectional rods. According to their price list they are reasonably priced, just have to find a distributor who stocks them.
54reo
62
Chester IL
Thanks,
Allen
I have several of these 3 piece kits still in the box. NSN 5975-00-878-3791. Complete with the wire, clamps, three sections of threaded rod, bronze couplers, drive bolt, and extraction disks. Anyone interested? I can post pics tomorrow.
I only have one slide hammer, sorry.
319
Lieutenant
3,347
58
Michigan
PM sent
