andybritt2002
- 0
- 0
- Chesapeake, VA
hey guys,
I took my center chunk section out of my rockwell axle to install a locker, went to put the bull gear back into the hole, put the races on the bearings, put the caps on and screwed the piece I highlighted in yellow in the pic down to squish the races onto the bearings etc. I marked the caps for which side they came off of etc so I know I have the right sides. How tight does this need to be?( the big circle screw in press with all the tabs on it" I used a flat bar to turn it, and what happens is after I get it screwed in as far as it was when i took it out..... the diff becomes very hard to turn then I cant at all by hand. Its not too terribly tight because if its much looser you can grab it and wiggle the whole thing around slightly. Did I accidently screw something up with the bearings on each end?
