Page 435 of 442 FirstFirst ... 335 385 425 431 432 433 434 435 436 437 438 439 ... LastLast
Results 4,341 to 4,350 of 4415
Thread: FLU419 SEE HMMH HME Owners group
  1. #4341
    Private
    Join Date
    Jun 2019
    North Stonington, CT
    Posts
    Thanks
    Default
    Hello - I am considering buying a SEE. Am interested in making New England contacts - I am in CT - near New London. I have about 8 acres - rough terrain, lets of rocks and trees. I'd use it mostly for land clearing projects - side hustle/gig. Not looking to generate any income with it. At the same time, I am expecting that it will take some cash input depending on how much the starting point needs. I am handy and at the same time, don't want to spend an excessive amount of time fixing break downs.
    Purpose of my post is to possibly find folks to dialogue with so I can decide whether I want to go this route or a more traditional path - backhoe or tractor.
    Thanks
  2. The Following User Says Thank You to GMJanz For This Useful Post:
    kira2235740 (06-26-2019)
  3. #4342
    4 Star General The FLU farm's Avatar
    Join Date
    Dec 2015
    The actual midwest, NM.
    Posts
    2,595
    Thanks
    1,219
    Default
  4. The Following 5 Users Say Thank You to The FLU farm For This Useful Post:
    Another Ahab (07-04-2019), Guyfang (07-05-2019), Migginsbros (07-05-2019), Pinsandpitons (07-04-2019), Sgt Jiggins (07-04-2019)
  5. #4343
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    181
    Thanks
    112
    Default
    I realize I may be stirring the pot, but I have no interest in getting the test box. Does anyone have any reason not to begin removing the STE/ICE-R related wires when I encounter them? I am starting with 21S and 21M which run from the starter to the big port in the cab.
  6. #4344
    Join Date
    Dec 2015
    Posts
    2,595
    Thanks
    1,219
    Default
    Ron, only a lack of time has prevented me from ripping all that crap out.
    I'm especially suspicious of the shunt by the batteries, which may be a problem source on my Winter SEE.
    Then again, with the system intact there's a 50/50 chance that a rodent will gnaw on a useless wire rather than one that actually does something.
  7. #4345
    General
    Join Date
    Oct 2014
    northern nh
    Posts
    492
    Thanks
    22
    Default
    It really looks like it was added on after the Mercedes factory built the base chassis so I sure would not worry about it.
    Unimog SEE, Unimog 1300L Ambulance
  8. The Following User Says Thank You to peakbagger For This Useful Post:
    Guyfang (07-10-2019)
  9. #4346
    Colonel alpine44's Avatar
    Join Date
    Jan 2014
    Asheville, NC - Elkton, MD
    Posts
    392
    Thanks
    Default
    Quote Originally Posted by rtrask View Post
    The whole STE/ICE-R harness is easy to remove after tilting the cab. Makes the rest of the wiring and plumbing easier to troubleshoot if necessary.
    1990 FLU419 SEE
    1986 M1009, 6.2L engine, 700R4/NP241, 4.10:1 14 bolt 8 lug rear, 10 bolt 8 lug front, 4" lift, 34.5" tires
    1993 M998 2-man troop carrier - SOLD
    MEP002A generator
    Gichner Expandable ISO shelter = my machine shop
  10. #4347
    Sergeant Major
    Join Date
    May 2017
    Littleton, Colorado
    Posts
    181
    Thanks
    112
    Default
    So far every one seems in agreement that getting rid of that crap is a step forward. I don't plan to focus strictly on removing it, but while I am working my way through my electrical woes if I trace something back to the STE/ICE-R, I will disconnect and if not too difficult drag it back to the source. I could probably just use wire cutters to remove, and ultimately that may be what I do, but for now I will not use the scorched earth approach.
    By his comments, it looks like Alpine removed the whole thing, has anyone else taken the plunge.
  11. The Following User Says Thank You to rtrask For This Useful Post:
    Another Ahab (07-10-2019)
  12. #4348
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    6,265
    Thanks
    12,096
    Default
    Quote Originally Posted by peakbagger View Post
    This is very true. It's a add on. You can take it off. But you all are focused on only the negative side of the STE/ICE system. And let me state here, the STE/ICE was a failure throughout the military. For three reasons. Soldiers could not use it/ and lost any confidence what so ever in it. It was too complicated. And last but not least, the system never got off the ground before the military "ditched it". No effort was made to correct known faults, to expand its uses or to make it simpler to use.
    OK. Now to the good points. Those pins in the C-plug all go to places that it might be handy to be able to check, without getting up, and moving around. Or opening something up. If you look at the points that the wires come from, you just might be surprised. I am not a CEE guy. Haven't looked at the wire Schmatices and checked those points out. But I have done so on equipment I do know well. Power generation. And there are more then several nice to be able to check voltages, available at my C1 plug. Now most of you don't work on the CEE everyday of your life. I did army power generation for about 28 years. Using that plug saved me a million miles, and often allowed me to work alone, insted of needing someone to go around on the other side to mesure voltage while I started the gen set. I also could use it to jump around several circuits, when they didn't work normally. So before you rip everything out, might want to look. And if it's not worth your time, then do it.
  13. The Following 2 Users Say Thank You to Guyfang For This Useful Post:
    Another Ahab (07-10-2019), Sgt Jiggins (07-10-2019)
  14. #4349
    General
    Join Date
    Oct 2014
    northern nh
    Posts
    492
    Thanks
    22
    Default
    Bad post
  15. #4350
    General
    Join Date
    Oct 2014
    northern nh
    Posts
    492
    Thanks
    22
    Default
    Quote Originally Posted by GMJanz View Post
    Thanks
    sorry i missed this one. I will give you my standard answer, it depends what you are comparing the see to. The see is not going to compete with a new on the lot digitally controlled tier 4 complaint cat, jd or case. On the other hand the cost for a see is a downpayment for what you would pay for a new one. You are not going to be able to work on a new cat or case as they require specialized diagnostic gear and software that you may or may not even be able to access. A see is extremely well documented and the technology is mostly 1960s, albeit the base chassis is german 1960s and the add on equipment on the rear deck is 1980s case so some translation is required on occasion. When you compare a see to an equivalent vintage cat, jd or case it has similar functionality and its highly likely that for what you are paying for good see with minimal hours you are getting a third hand jd, case or cat with lots of hours that is worn out and going to require constant repair.
    the german approach uses a lot of air assist systems to do stuff that may be manual linkage on us product and the germans didnt color code the see electrical harness so it bit more a challenge to chase electrical gremlins.
    one big difference to be aware of is a see does not have hydraulic or manual thumb and that does limit the backhoes use for moving rocks around which may limit its use for land clearing. There is thread on add on thumbs but my read is its tough to fit one on that does not interfere with stowing the bucket in preparation to stowing the backhoe. Its apparently a tight fit. I have the somewhat rare optional hien werner rock/ledge bucket and its also a very tight fit. I can imagine how a thumb would fit but haven't looked in detail. Btw, the hein werner optional bucket is great for digging in rock and rotten ledge but not so good at making a clean hole. I rarely see ads listing this bucket on see so expect the folks who don't have it don't realize the difference. The other difference to understand is the loader is not a bulldozer, its a loader. Fine for moving loose dirt and smoothing it out but don't expect to be able to dig into virgin soil. Another thing to be aware of is like a standard backhoe loader you are nor going anywhere quickly. It may have theoretical top road speed of 50 mph but anything over 30 mph is pretty hairy due to a combination of heavy long throw springs, loose sidewall tires and a loader hanging well ahead of the front tires on short wheelbase truck.
    one of the forbidden subjects of this forum is talking details on insurance. Before you buy a see you need to do research on if you can title it in your state and use it on the road and if you can get insurance. In many cases getting anything more than liability is difficult if not impossible but do the homework up front. If you are doing side gigs for some one else realize you may be doing the work "naked" and any claims come out of your pocket.
    you did mention a key thing, you need to be "handy" as there is no backup beyond various forums, so if you cant fix it there is no one to fix it for you. If you try to pay someone you are basically paying them to gain experience that you should be getting for yourself. You will need to "tool up" and harbor freight will be your friend for the really big metric tools, jack stands and jacks you will need. A fyi on forums, the only see specific forum is this one, there are other unimog forums but sees seem to be regarded as "b*st*rd stepchildren", the folks may try to help but realize that their experience is the 406 chassis or the large sbus so they can not contribute much if you have backhoe issues. Most of the see knowledge on this forum including myself are first time owners of unimogs and we are learning as we go.
    now the issue of fixing break downs. Its very dependent on the individual see you buy. If the see hasn't been rebuilt by the government (many have been) you are looking at 30 year old equipment that was stored in very hot sunny conditions that are hard on rubber and resilient seals. They may not be worn out, but can suffer from lack of use. That means tires at $400 to $500 a piece, lots of hydraulic hoses, hydraulic cylinder seals, all the fluids will need to be replaced. The air system usually needs to be taken apart and cleaned out various rubber like flexible bushings also will crop up, like steering linkage boots (that are no longer available) which means potential home brew fixes or buying new steering linkage from europe (not cheap). So that cheap see that hasn't been rebuilt may come with $5k of things you may need to replace all at once or just live with the down time and fix when broke. I tend to go with the fix when broke as i strictly use it for myself. A rebuilt unit depending on
    the rebuild date may manes 20 to 25 years newer rubber parts.
    you are at disadvantage in new england as most of the sees were down south in depots when finally sold. It costs 3 to 4k for shipping from down south. There were some sees transferred to state or local governments for reuse up in new england but these have to be looked at carefully as they seem to be units that were not rebuilt and may have suffered from lack of maintenance due to untrained mechanics. There is only one "sort of dealer" and that's c&c equipment who have been buying and selling sees over the course of the surplus cycle and even they seem to be getting out of it.
  16. The Following 2 Users Say Thank You to peakbagger For This Useful Post:
    Another Ahab (07-11-2019), lurkMcGurk (08-01-2019)
Similar Threads
  1. Unimog FLU419 Tractor thing?
    By jluv1185 in forum Unimogs
    Last Post: 07-21-2019, 16:39
  2. HME, SEE, HMMH same chassis?
    By wehring in forum Unimogs
    Last Post: 01-03-2016, 16:36
  3. Replies: 5
    Last Post: 05-21-2013, 07:16
  4. FLU10344 (HMMH) video
    By forestMog in forum Unimogs
    Last Post: 11-06-2011, 00:41
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
