Page 16 of 30 FirstFirst ... 6 12 13 14 15 16 17 18 19 20 26 ... LastLast
Results 151 to 160 of 298
Thread: Engine knocking LDS-456
  1. #151
    Colonel davidb56's Avatar
    Join Date
    Feb 2019
    Bonners Ferry Idaho
    Posts
    307
    Thanks
    413
    Default
    I tried to edit my rant because it got off topic, but Frank captured it in a quote. I never really noticed how I spell Duece, as I let the spell checker automatically change everything....it does it even if I want to use a different word, so why bother?
  2. #152
    Colonel Oerthedge21's Avatar
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    Got 3 piston sets in their liners and dropped in, and managed to get the rear head on. Followed the torque chart, and dropped in the rocker arm assembly and lifters. Couldn't grab a picture since I'm working in the driveway and it got dark when those went on, no now the main part is half done I guess, took tomorrow off work so I hope to get the front 3 in as well.IMG_20190922_182328466.jpg
    1968 M35A2C W/W
    1985 CUCV M1010 (Sold)
  3. The Following 5 Users Say Thank You to Oerthedge21 For This Useful Post:
    cattlerepairman (09-23-2019), davidb56 (09-22-2019), Menaces Nemesis (09-23-2019), rustystud (09-23-2019), silverstate55 (09-23-2019)
  4. #153
    Corporal
    Join Date
    Mar 2018
    Riverhead, NY
    Posts
    49
    Thanks
    23
    Default
    Based on this picture it looks like the heads can be torqued down using regular tools. Is there a reason to need those offset 7/8" wrenches when changing head gaskets on this or LDT engines? Are guys only using them to check or re-torque the heads after everything else has been put back on?
  5. #154
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    Yes it's doable with regular tools, but you absolutely need that funky offset wrench. The nuts on the driver's side edge of the block are inaccessible without it. I'll put up a picture in a bit when I get out there to work on it some more. You can make the tool yourself if you have a few basic tools and a welder. I'll post up a pic of the one I made as well.
    1968 M35A2C W/W
  6. The Following 3 Users Say Thank You to Oerthedge21 For This Useful Post:
    Menaces Nemesis (09-23-2019), NY Tom (09-23-2019), silverstate55 (09-23-2019)
  7. #155
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    These are the nuts, not too terrible on the rear head but on the front the oil cooler assembly sites right there and you can't even fit a wrench down there. Crowsfoots don't fit either. What I did was cut a 3/4 socket down and welded it to the end of a 1/2" extension at a slight angle. Allows you to use a torque wrench up out of the way of the headIMG_20190923_095633830.jpgIMG_20190923_095737665_HDR.jpg
    1968 M35A2C W/W
  8. The Following 3 Users Say Thank You to Oerthedge21 For This Useful Post:
    davidb56 (09-23-2019), Menaces Nemesis (09-23-2019), silverstate55 (09-23-2019)
  9. #156
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    3,999
    Thanks
    2,813
    Default
    Quote Originally Posted by davidb56 View Post
    Not to long ago a moderator removed all postings with Deuce spelled wrong.
    Turn off the automatic spellcheck before you send something nasty to someone that you didn't even intend to be that way.
    I was here, had a good time.
  10. The Following User Says Thank You to frank8003 For This Useful Post:
  11. #157
    Join Date
    May 2012
    Posts
    3,999
    Thanks
    2,813
    Default
    Quote Originally Posted by Oerthedge21 View Post
    There is numerous many and "choking point" amount of threads on the "crazy wrench" and what it means in offset vis-a-vis actual torque applied. lots of photos and information to be had, this is the TM stuff.
    crazy wrench 1.pdf
    crazy wrench 2.pdf
    crazy wrench 3.pdf
  12. The Following 4 Users Say Thank You to frank8003 For This Useful Post:
    davidb56 (09-23-2019), Menaces Nemesis (09-23-2019), Oerthedge21 (09-23-2019), silverstate55 (09-23-2019)
  13. #158
    Join Date
    May 2012
    Posts
    3,999
    Thanks
    2,813
  14. The Following 2 Users Say Thank You to frank8003 For This Useful Post:
    Menaces Nemesis (09-23-2019), silverstate55 (09-24-2019)
  15. #159
    Join Date
    May 2012
    Posts
    3,999
    Thanks
    2,813
    Default
    and PS magazine which will not upload ............
    Issue 596, July 2002
    is 35 MB so One would go find that as it can not upload here.
    Yes, I will e-mail it to whomever would like to read it or whomever can go find it and read it otherwise.
  16. The Following User Says Thank You to frank8003 For This Useful Post:
  17. #160
    Corporal
    Join Date
    Mar 2018
    Riverhead, NY
    Posts
    49
    Thanks
    23
    Default
    [QUOTE=Oerthedge21;2239649]These are the nuts, not too terrible on the rear head but on the front the oil cooler assembly sites right there and you can't even fit a wrench down there. Crowsfoots don't fit either.
    Oh yeah how could I have forgotten that side. Thanks for posting that up.
    Tom
  18. The Following User Says Thank You to NY Tom For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
