Page 18 of 30 FirstFirst ... 8 14 15 16 17 18 19 20 21 22 28 ... LastLast
Results 171 to 180 of 298
Thread: Engine knocking LDS-456
  1. #171
    Colonel Oerthedge21's Avatar
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    Don't worry I have plenty of things left to fix before I get to those little odds and ends. Still need to do a major brake adjustment on all wheels, front axle boots and seals, possibly rear axle seals, who knows what else
    1968 M35A2C W/W
    1985 CUCV M1010 (Sold)
  2. The Following User Says Thank You to Oerthedge21 For This Useful Post:
    Menaces Nemesis (10-25-2019)
  3. #172
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    Started adding coolant today while waiting for the tranny to drain, got back under to check the progress and saw coolant dripping. Been a while since my heart sank like that. Thankfully, upon closer inspection it was leaking out of the rear of the intake manifold where I forgot to tighten one of the countless nuts that hold it on. Always double check the intake nuts if you take it off. Just waiting on the injectors now, hoping for a call tomorrow, we'll see
    1968 M35A2C W/W
  4. The Following 2 Users Say Thank You to Oerthedge21 For This Useful Post:
    Menaces Nemesis (10-25-2019), silverstate55 (10-01-2019)
  5. #173
    4 Star General cattlerepairman's Avatar
    Join Date
    Jul 2007
    NORTH (Canada)
    MVPA
    37751E
    Posts
    2,050
    Thanks
    1,038
    Default
    I know that awful feeling....and the relief when you find out that it is a quick fix!
    Good that you found that now. If you had run the engine, you would also have burnt you hand on the exhaust manifold for good meaure while tightening the nut, just so Murphy can have a better laugh.
    MVPA member. 1974 M35A2C w/w "Queen Lola", rebuilt LDS-465-1A, "D" turbo, Waterloo Overdrive upgrade. Med towbar, 11.00R20 Goodyear G286, flipped hubs, remote brake fluid reservoir, spin-on filters, bypassed FDC, LED taillights, LED headlights, LED turn signals, WESTACH EGT/boost gauge, AVM lockout hubs, LED convoy light, LED lollipop lights, HMMWV seat on air ride base, M211 dash passenger grab handle, hood lift kit, 24V solargizer/battery minder, ether start kit, flasher module mod, heavy duty dog bone ends, M35A3 aluminium fuel tank.
  6. The Following 3 Users Say Thank You to cattlerepairman For This Useful Post:
    Menaces Nemesis (10-25-2019), rustystud (10-02-2019), silverstate55 (10-02-2019)
  7. #174
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    The shop called yesterday, nozzles I ordered were the wrong ones for my injector bodies. So now I have a bunch of two hole nozzles laying around that I don't need. I can get the NSN and PN off the boxes if anyone is interested, I'll sell them cheap. She gave me the PN I need to find so now it'll be probably another week before I get the right ones and get them back
    1968 M35A2C W/W
  8. #175
    Super Moderator gringeltaube's Avatar
    Join Date
    May 2005
    Montevideo/Uruguay
    Posts
    5,813
    Thanks
    1,340
    Default
    Quote Originally Posted by Oerthedge21 View Post
    Not sure what those 1-hole nozzles are going to cost you, but you could buy the whole injector here, NOS.
  9. The Following User Says Thank You to gringeltaube For This Useful Post:
    silverstate55 (10-07-2019)
  10. #176
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    I'm replacing the old 1 hole nozzles with the upgraded 2 hole versions. I figure if I'm gonna spend the money on new nozzles ill just get the better set as opposed to the less efficient 1 hole set. Plus I've read that the 2 hole nozzles are supposed to clean up the exhaust a bit, which is great because my LDS smokes like a train and it's somewhat annoying, plus less smoke means a cleaner burn which means a more efficient engine, so it's a win win no matter what.
    1968 M35A2C W/W
  11. The Following 2 Users Say Thank You to Oerthedge21 For This Useful Post:
    Menaces Nemesis (10-25-2019), silverstate55 (10-07-2019)
  12. #177
    Join Date
    Jul 2007
    NORTH (Canada)
    MVPA
    37751E
    Posts
    2,050
    Thanks
    1,038
    Default
    I am not sure about the "not the right nozzle for the injector" business. I thought the nozzles were interchangeable, regardless of the injector (shim or no shim style). Not sure what the problem is?
  13. #178
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    I thought so too, but she said that the nozzle will not line up with the pins in the injector body and the needle inside the nozzle is totally different and will not seat right. I did, upon closer inspection, notice the top of the nozzle is flat as opposed to having a ring/groove cut into it like the nozzles that came out.
    1968 M35A2C W/W
  14. #179
    Join Date
    Apr 2015
    Northford CT
    Posts
    222
    Thanks
    12
    Default
    And I have a mix of shim and screw style bodies apparently, and these nozzles won't fit any of them so my guess is maybe they're not what I am told, or did the lds-427 or 465-2 use a different injector maybe, and these just so happen to be for one of those?
    1968 M35A2C W/W
  15. #180
    Join Date
    May 2005
    Montevideo/Uruguay
    Posts
    5,813
    Thanks
    1,340
    Default
    Yes, please post the numbers. AFAIK, there is only one existing model nozzle with the 2-holes (P/N 7748882).
    From what you said, that the two-holes don't work in your holders, I assumed you had to go back to the one-hole nozzles.
    Leaves me wondering what exactly is wrong with those you already got?
  16. The Following User Says Thank You to gringeltaube For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
