Updated pictures:
Here is the filter bracket…..
I planned to mount it on the other side of the bumper plate, but I made it too deep. I will have to dress it up or re weld it another day. Just need it functional.
I have it under vacuum. So far it is holding.
The hoses are all zip tied and everything looks good to me.
I ordered a small ball valve for the heater core lines in case reversing the flow direction does not fix the heat always on issue. I will use it only in hot months if needed.
5/8" Heater Hose Shut Off Valve 16mm OD Brass Ball Valve 90 Degree Turn Full Port 1pc https://a.co/d/5lVY2A6
