storeman
- 52
- 48
- Mathews County, VA
1800,
You want to keep the unit as original as possible.
Let me suggest a different approach, if you have a tap set. I noted in your pictures of trying to pull the fan that you have a puller identical to the one I used to use on the fan. NAPA sells a straight bar heavy unit for about $25 that works much better for me.
My recommendation would be go back to the fan, get a better puller and try again with 5/16" bolts. If you pull the threads out, drill and tap for 3/8" or 7/16" bolts. I've had to do that twice and use a hammer on the fan base, to boot. If I recall correctly, I had to use the 7/16 drill to relieve the puller a bit to allow free movement, or perhaps I used 1/2 to relieve it's slot.
The puller you are using tends to pull at an angle IMO and I don't use it anymore. Given that it is a keyed shaft, any angle off true makes it impossible to pull the fan.
Jerry
Jerry
