nickd
- 51
- 28
- Newport, Delaware
I just received my new lock out hubs from John Tennis and here are a few pictures of the hubs and measurements showing the difference in height compared to the stock hub. The "kit" included replacement hub gaskets, instructions, and 2 hubs. The instructions mentioned removing the hub top cover but that is not necessary for the deuce as there is no clip behind the hub. This is an unbolt the old and install the new modification. It took about an hour of actual work after I rounded up the impact gun. I also jacked up the front axle and checked my wheel bearings (found the passengers side a little loose and tightened it up.
I was unable to get a good picture of the hubs installed due the the lack of side room in the garage. I installed them just in time to clean up and head home so the reinstallation of the rear most drive shaft and a test drive will follow.
The hubs are constructed of a heavy casting of aluminum with steel internals. The hubs are about 1" taller than the stock hubs
