Clunking sound when I shift from P to D
Mogman
10,473
Papalote, TX
it seems to be coming from here
<---- in this video it is more evident
That U joint is bad at the transfer case, you can clearly see the play in it (at the 2 second time mark), also any time you see red (rust) around a U joint it is likely bad.
MarkM
1,148
2,097
WOBURN. MA.
Yep it's a bad U Joint . Should be an easy fix but change them both out F/R While your in there.
Mark
Tiwaz
65
Miami Beach
can anyone suggest a part number or a vendor?
(are both joints the same part number?)
I am not very mechanically inclined and afraid of buying the wrong parts.
2007 M1151A1
